Ability to send e-mail and SMS to our users from Pressence
Discussion in 'Ideas' started by jed, Aug 3, 2016.
Ability to send e-mail and SMS to our users from Pressence 3 5 2votes
3/5, 2 votes
  1. jed
    jed New Member
    Feb 1, 2010
    138
    41
    We would like the ability to right click on a extension in our pressence screen or contacts, and be able to send a SMS to this extension´s cell phonenumber. (just as you can right click in Contacts and select send an e-mail)
    The SMS solution could be as a e-mail, just by using the cellphonenumber@sms.domain.com to use a external SMS Gateway.
    This will help receptionist´s sending messeages to colluages the way they perfere.
    Thank you for your wote..
    /Jesper
    JED
    Edit, found 2 spelling errors and corercted. :oops:
    #1 jed, Aug 3, 2016
  2. jed
    jed New Member
    Feb 1, 2010
    138
    41
    Not any one else, that could use the ability to send a SMS directly?
    We are having more and more that ask for the solution to send a SMS directly by Rightclicking on a internal or external contact.
    Thank you so much
    #2 jed, May 24, 2017
  3. mortenjorge
    Apr 1, 2015
    58
    11
    We still need to send SMS.. At the moment, only email works..
    We need support for sms gateway.
    jed likes this.
