Ability to set display name in Yealink DECT
Discussion in 'Ideas' started by josea, Dec 14, 2017.
Ability to set display name in Yealink DECT 5 5 2votes
5/5, 2 votes
  1. josea
    Sep 13, 2017
    23
    5
    Display names in Yealink DECT (W56P) is set to the extension number (in the template:
    handset.1.name = %%ext_int_num_01%%).
    It would be good to give access to manage that. People tend to prefer to display their names.
    Ideally it would be some sort of field like "Display Name Template", if blank you would defaulted, if not, it would use that code (ie: insert the code into the template).
