ability to turn off Exchange Contact Sync
Discussion in '3CX Phone System - General' started by craigreilly, Nov 12, 2013.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,551
    298
    I tried removing all of the entries in Company Directory Sync - but the information remained in the phonebook, even after I restarted the company directory service.
  2. AndreasP_3CX
    AndreasP_3CX New Member
    3CX Support
    Feb 15, 2013
    196
    Hi craigreilly,
    You cannot delete any contacts synchronized through MS Exchange from your Company Phonebook. The contacts need to be deleted from Exchange first and the 3CX Company Phonebook will be updated automatically (also mentioned in the 3CX Phone System 12 User Manual here: http://www.3cx.com/manual/3CXPhoneSystemManual12.pdf . The other way to do this is to remove the public folder to synchronize in Settings>>Advanced>>Company Directory Sync>> Configure Public Folders to Synchronize and the company phonebook will be updated automatically. If you have any further questions please don't hesitate to contact us.
    Best Regards
  3. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    Sorry for resurrecting an old post but I wanted to find out if there were any new solutions to this.
    When employees are replaced we reuse extensions so having the previous employees contacts causes issue.
    thanks.
