Ability to use existing Groups in paging and ring groups
Discussion in 'Ideas' started by Flash99, Mar 2, 2018.
Ability to use existing Groups in paging and ring groups 5 5 2votes
5/5, 2 votes
  1. Flash99
    Aug 3, 2017
    98
    8
    We already have extensions in Groups for Outbound Rules and we want to use same groups as Paging groups.
    In currnet version we will need to reenter all group memebrs under paging group.
    craigreilly likes this.
  2. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    893
    154
    There is no option to do this in 3CX, or to automate the synchronization process. However, you could write a service that synchronizes the extension groups and ring groups using the 3CX Call Control API. We can help if needed.
  3. Flash99
    Aug 3, 2017
    98
    8
    Ideally we want to do it without the use of external tools
    We already have "Extension Groups" in 3CX so I think its very logical and expected that you would be able to use them as part of paging group
