Ablity to set BLF on a Ring Group or Paging Group
Discussion in 'Ideas' started by craigreilly, Nov 12, 2015.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,591
    309
    I set a BLF manually using the Template - and the light is GREEN when the Paging Group is not in use. When it is in use it is RED. It would be nice if I could do this without a template mod.
