Abyss Web server error
Discussion in '3CX Phone System - General' started by stuart.rendall, Oct 26, 2010.
  1. stuart.rendall
    May 26, 2010
    25
    When trying to access the phone system using a web browser or the 'myphone' portal the following error message is displayed-
    Error 500
    Internal Server Error
    Powered by Abyss Web Server X1
    Copyright © Aprelium - 2001-2010
    The dedicated management console works fine - as does most other aspects of the system (v9.0.13545.592 SP.3).
    What would be the most practical things to investigate be?
  2. MichaelB
    MichaelB 3CX Team
    3CX Support
    Aug 25, 2009
    415
    19
    Hi, do you have an anti-virus installed where the 3cxPhonsystem is running?
    Error 500 - Internal Server means that abyss is constantly crashing due to an application running in your system.
    Please check and let me know.
    Thanks and Regards.
  3. stuart.rendall
    May 26, 2010
    25
    Yes, I performed a reinstall of the system and shortly after, the anti virus software determined the FGIDOTNET2.0.exe process as malware, and attempted to stop it.
    The anti virus log showed that it had done this previously when the problem had made itself apparent.
  4. MichaelB
    MichaelB 3CX Team
    3CX Support
    Aug 25, 2009
    415
    19
    Yes, please disable your antivirus from your system.
    Also you will need to install the 3cx Phone system again to avoid having missing files / corrupted.
  5. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    If you need to leave your anti virus running, then get it to ignore the 3cx directories and abyss server.
