Accept calls for unregistered extentions
Discussion in 'Ideas' started by Kevin-Balans, Nov 27, 2017.
  1. Kevin-Balans
    Nov 27, 2017
    I want to be able to let unregistered extentions "accept" calls (so you can use such extention in Queue's and Ring groups based on status).
