Access Company Phonebook over Database-Phone Numbers missing
Discussion in '3CX Phone System - General' started by Mini25, May 30, 2014.
  1. Mini25
    May 28, 2014
    is there a way to access the 3cx company phone book directly over database? 3cx loads different Exchange contact folders into the company phone book and they are also displayed correctly on the management interface. But if i look on the phonebook table of the phone system i could not see the whole phone book. Although der are all contacts inside this table there are some phone numbers missing.
    For example:
    If i create a new contact in a global outlook exchange folder with a phonnumber in "company phone number", the number ist displayed in management interface after 3cx does the import of the exchange contact folder. But if I take a look into the database I could not find this number. Also if the phone book is synchronized to the different IP Desk phones, these numbers won't be transfered. But they are available over 3cx sofphone client. Where does 3cx store those phone numbers?
    It would be great, if someone could help me...
    Thanks in advance.
    Best regards
    Mini25
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Re: Access Company Phonebook over Database-Phone Numbers mis
    Hi there,
    The phone numbers going in hardphones directories are the ones set in Mobile field of the company phonebook contacts. Kindly ensure these fields are filled in those missing numbers you noticed.
