Access from chrome on Android
Discussion in 'Android' started by Peter Richardson, Dec 25, 2017.
  1. Peter Richardson
    Peter Richardson New Member
    Apr 6, 2017
    198
    8
    Hi all,
    I'm using a HTC U Ultra. I use Chrome to log into the PBX and when I go to extensions, the view keeps scrolling me back to the top. I can't view any extensions past the first one or two before it scrolls back to the top. Even if I hold my finger on it.
    Also, the view in either portrait or landscape mode obscures most of the information. Please see attached.
    This has been an issue even on my previous two phones, the HTC One M9 and HTC One M8, so for about one to two years this issue has been going on.
    I've just tested it on an iPhone 7 and although it doesn't automatically scroll me to the top, it does obscure the information which makes it difficult or impossible to select the desired extension to edit. Please see last photo.
    #1 Peter Richardson, Dec 25, 2017
  2. Peter Richardson
    Apr 6, 2017
    198
    8
  3. Peter Richardson
    Apr 6, 2017
    198
    8
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @Peter Richardson
    Please note that the mobile version of the app was primarily designed for tablets where it works and looks ok. On a phone you can request the desktop site for now where you can zoom in and operate it like you would on your desktop pc. I can see the issue you have mentioned and i will look into it to see if something can be done to change the behaviour.
  5. Peter Richardson
    Apr 6, 2017
    198
    8
    Thanks very much @YiannisH_3CX
    I wonder why any emphasis would be put on managing it from a tablet, considering most of us carry our mobile phones with us 24/7, and a lot of us use our phones for managing systems on the go.
    Will you update us here when you have some progress/news on this one?
  6. YiannisH_3CX
    May 10, 2016
    6,016
    421
    Yes, i will let you know once i have something.
