Access restrictions of Web Management Console
Discussion in '3CX Phone System - General' started by chikara sugiyama, Aug 20, 2014.
  1. chikara sugiyama
    Jun 15, 2014
    22
    Hi there
    I believe the access method of limiting user.
    Access restrictions following contents possible?
    · Call reports Permissions
    · Web Management Console access is not permitted
    Thank you for your confirmation.
  2. 3CXNP
    3CXNP Support Team
    3CX Support
    Apr 25, 2014
    44
    Hi there,
    You can enable access to the web reports by going into the extension settings of the extension you want to give access to.
    Go to the "options" tab
    In the "Access" section, you can give access to the web reports.
    The username will be the extension number.
    The password is the "Access password for 3CX Web Services" in the "access" section.
    You can also optionally allow the user access to the settings in the web reports (Allow Admin Operations"
    You can also allow optionally, the capability ro download call recordings.
    Hope this helps.
  3. chikara sugiyama
    Jun 15, 2014
    22
