- Joined
- Mar 24, 2010
- Messages
- 4
- Reaction score
- 0
I am rather new to this IP PBX stuff, so pardon my ignorance.
here it goes.
I have installed a 3CX PBX Solution to work with local and remote extensions, using both Softphones and hardware phones.
so far, so good.
now i want to connect the External lines Phone central to 3CX. How do I do that ?
the Central is a ELMEG T-484
This equipment has both usb and RJ45 connections. and it receives data from a ISDN line swith 10 DDI.
Can i interface directly with 3CX ? do i need any separate piece or hardware ? those FXO or something that I have read about
around here ? Can please anyone help ?
Thank you in advance
Pedro Caldeira
P.S: The ELMEG T484 Basic Features.
PBX integrated into the network
The network connection of the elmeg T484 makes the system directly accessible via the LAN. With the drivers configured for LAN-TAPI and LAN-CAPI, users have access to telephone functions on their PCs. This can be a direct link between PCs with Outlook contact data and the connected telephones or the use of the ISDN channels of the PBX as a fax line directly to the PC. Management can also comfortably access the system directly via a PC connected to the network or via a USB link to the telecom system.
Base Modul:
1 x S0 internal / external usable
1 x S0 internal
8 x a/b internal
Integrated IP-Router for Internet access via SL or ISDN with:
- 1 SL/WAN interface Ethernet (for external SL modem)
- 1 LAN interface,10/100 Mbps Fast Ethernet
- 1 LAN interface USB
LEDs for indication of Power, ISDN, LAN, WAN
1 module slot for expansion with:
Module 2 x S0, of which 1 x S0 internal/external, 1 x S0 internal
or
Module 4 x a/b internal
or
Module 2 POTS (connection of 2 analogue exchange lines)
or
Module 4 POTS (connection of 4 analogue exchange lines)
1 slot for:
Module TFE (door hands free)
or
Module contacts comprising 6 signal inputs/sensors and 3 switching contacts/actuators
1 slot for:
Module 4 DSP for direct connection to SIP provider
And 1 slot for:
Compact Flash Card
And in addition:´
FSM (fine protective module against excess voltage
here it goes.
so far, so good.
Pedro Caldeira
Base Modul:
1 x S0 internal
8 x a/b internal
or
or
or
1 slot for:
or
1 slot for:
And 1 slot for:
Compact Flash Card
And in addition:´
