Implemented Access to update settings
Discussion in 'Ideas' started by giwm, Mar 4, 2017.
  1. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    With SP5, there are automatic update settings that cannot be accessed unless there is an update available. We should be able to adjust settings without having to have an update waiting.
  2. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    Well... Apparently you can access it through the dashboard. Perhaps adding a button under Settings would be more obvious.
