Hi @Alldayrr,
Accessing the 3CX database is an unsupported procedure. It is recommended that you use the 3CX Call Control API to access this information:
https://www.3cx.com/docs/call-control-api/
Kind regards.
We are working on a Linux version of Voicemail Manager. If you are willing to work with beta code, I can probably get you an early release.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
