Accessing Recorded Calls
Discussion in '3CX Phone System - General' started by rtfm, Sep 29, 2010.
  1. rtfm
    Aug 10, 2010
    Hi Team,
    I know you can record calls either via the 3CX Assistant on extension by extension via the admin console, however how does the user access the recordings?
    They are only stored on the server. I would have thought the web-portal would have been a sensible place for these to live next to the recorded voicemails...
    Thanks in advance for your help.
