Accidentally deleted "VMDIALOUTENABLED" from parameters...
Discussion in '3CX Phone System - General' started by Robert Thompson, Jun 21, 2017.
  1. Robert Thompson
    Jun 21, 2017
    Hello:
    How do I restore the "VMDIALOUTENABLED" parameter?
    Or, must I do a re-install?
    Thanks,
    Rob.
  2. teldata1
    Aug 24, 2015
    63
    You may be able to re-add the parameter by clicking "Add" in the Parameters section, and simply entering in the original values. I've attached a picture of what you should enter.
    Value: 0 for disable, 1 for enable
    Hope that works for you
  3. Robert Thompson
    Jun 21, 2017
    Thank you. :)
    I have added it back and it looks ok - just one question: once a call is directed to VM, how do you place an outgoing call? Do you need to enter a special code to get the dial-tone?
    Thanks,
    Rob.
  4. teldata1
    Aug 24, 2015
    63
    Enter the voicemail password, press 9, then press 3. Dial the phone number and you should be good to go!
