Account ID or Credentials ID
Discussion in 'CRM / Helpdesk / App Integration' started by Gavris Bogdan, Mar 22, 2018.
  1. Gavris Bogdan
    Mar 19, 2018
    Hy, i have a plugIn app where I try to send the ID of the Account loged in the 3CX Client...
    I managed to take the number is calling but I don't find how to take the ID of the Account.
    I searched in the CallInformation, IMyPhoneCallHandler, MyPhoneStatus and nothing...
    The app is in C# using Visual Studio 2015
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,351
    108
    Hello @Gavris Bogdan,
    When you create your plugin, you can subscribe to the following event:
    IMyPhoneCallHandler.OnMyPhoneStatusChanged
    When you do it, when 3CXPhone starts and successfully logins using your extension, you can get the extension information as follows:
    Code:
    private void onMyPhoneStatusChanged(object sender, MyPhoneStatus status)
      if (status == MyPhoneStatus.LoggedIn)
        extensionInfo = sender as IExtensionInfo;
    The IExtensionInfo has a property "Number" which you can use to get the extension number.
    Is that the information you need?
    Kind regards.
    Gavris Bogdan likes this.
  3. Gavris Bogdan
    Mar 19, 2018
    Yes, this it is. Thx for the hint :)
