Solved Account Label for iOS and Android client
Discussion in 'iOS' started by macfusion, Dec 13, 2016.
  1. macfusion
    Aug 4, 2015
    5
    I have several 3CXPhone different customer Accounts defined on my iOS device and often switch between them to directly call customers. It would be useful if a label could be added such as Acme Corp 1, Acme Corp 2 to the accounts so I could immediately identify the correct extension account to activate.
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    in iOS client, you may edit Account's name: Settings/Accounts/account/Name field.
    In the current version, it will be preserved until you re-provision that account, when it will be overwritten by the Display Name.
  3. macfusion
    Aug 4, 2015
    5
    Thanks. A most useful hint.
  4. Vali_3CX
    Dec 12, 2008
    1,527
    71
    @macfusion
    We just released a new BETA of our iOS client, 15.2.4.118, which fixes also the account name being "overwritten" by the Display Name when re-provisioned, so it should work properly now.
  5. Vali_3CX
    Dec 12, 2008
    1,527
    71
    We just released the "official" 15.2.4.122, it contains the fix.
