Account switching
Discussion in 'Android' started by nkolios, Jun 27, 2015.
  1. nkolios
    Jun 27, 2015
    I have just installed Version 12 of the Android app onto a new Samsung Galaxy S6, the app generally works fine. I have installed two accounts and for some reason after a short period of time the app logs me out of one Account and logs me into another. Is there anyway to stop this or prioritise the app to log into a particular Account as a preference?
    11,116
    329
    That's a new one for me. Normally, the account that you closed the application with, will be that one that it starts with when re-opened. I've never had it switch on it's own.
  3. nkolios
    Jun 27, 2015
    Its a bit of a weird one. I have tried deleting the profile from the phone and it still seems to re-install it. It doesn't do this on an iPhone. I'm using a Galaxy 6s, I know its new so perhaps there is a bug. :-(
