acer iconia tab a501
Discussion in 'Android' started by vpaulo, Feb 7, 2012.
  1. vpaulo
    Jun 24, 2009
    23
    Hi, does 3cxphone work at android 3.2 release?
    10,833
    293
    The end of the first paragraph seems to say "no".
    http://www.3cx.com/blog/3cxphone/android/
    I didn't think that the Android market would show, let alone let you download Apps that are not compatible with your devices version of the operating system. You can always try it, post back with you experience.
    Just don't get too upset if it doesn't work for you. I'm sure that later Android versions will eventually be covered.
