ACK is not received from sip
Discussion in '3CX Phone System - General' started by pbueno@mapbit.com, Jan 11, 2013.
  1. pbueno@mapbit.com
    Jan 11, 2013
    8
    The "ACK is not received from sip" has been discussed many times but I have not found the definite resolution. My situation is as follows:
    Setup
    1. 3CX Phone System V11 running on Amazon EC2 Win with Elastic IP (Fixed IP).
    2. "Turn off STUN requests" enabled in 3CX Network setting.
    3. External Extensions setup for 3CXPhone on windows and Aastra 6730i deskphones.
    4. 3CX Firewall check passes all checks.
    Problem:
    ** Outbound Calls from Aastra 6730i drop after 30 seconds.
    ** 3CX Server Activity Log shows "ACK is not received from sip:222@<EC2 Elastic Public IP>:5060"
    ** When making an outbound call from the Aastra the log shows "Extn:222 has joined, contact <sip:222@81.82.65.64:1024>"
    Inbound Calls to all extensions (3CXPhone and Aastra) work fine.
    Outbound Calls from 3CXPhone on windows, which is on the same LAN as the Aastra 6730i, works fine.
    Any suggestions.
  2. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    Does this still happen if you DO have STUN enabled and in use on your SIP Trunk gateway?
    best regards
  3. pbueno@mapbit.com
    Jan 11, 2013
    8
    Yes with Stun enabled I still have this problem
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    829
    50
    Are you using the 3CXPhone as a standalone app. or is it an extension of the 3CX Phone System?
    The 30 second problem sounds like your router closes his internal ports. To held this ports open you can try to use the Keep Alive option “Enable Keep Alive” which can be found here
    Settings >> General >> Global Options >> System Wide Options.
  5. pbueno@mapbit.com
    Jan 11, 2013
    8
    “Enable Keep Alive” is enabled.
    The configuration is as follows:
    3CX Phone Sustem V11 on AWS EC2 Instance.
    3CXPhone windows softphone working fine
    AASTRA 6730i working fine for inbound calls but droping outboud calls after 30seconds with "ACK is not received from sip"
  6. complex1
    Jan 25, 2010
    829
    50
    Because you are using de Aastra as external extension of 3CX, have you enable STUN server in the phone? Also set the proper SIP port, enabled the Rport function and in your local router forward/enabled the correct ports?
    Which extension number has the 3CXPhone you are using?
  7. pbueno@mapbit.com
    Jan 11, 2013
    8
    Stun server is specified in the Aastra configuration on port 5060 and Rport function is enabled. Extension of the Aastra is 222. Extension of the 3CXPhone is 100
  8. complex1
    Jan 25, 2010
    829
    50
    Have you read these two blog posts?
    1. read the end of this post: http://www.3cx.com/blog/voip-howto/remote-extensions/
    (Please note that the Aastra as an External Extension is not supported by 3CX.)
    2. Troubleshooting.....: http://www.3cx.com/blog/voip-howto/troubleshooting-direct-remote-extension/
  9. pbueno@mapbit.com
    Jan 11, 2013
    8
    Thank you for the links. I searched for guidance on setting up the Aastra 6730i and after changing the Codec 1 setting to G.722 at Codec 2 to G.711a (8K). It seems to not drop outgoing calls after 30 Seconds anymore. I will do some more testing and review the 3CX Phone System Server Activity log.
  10. pbueno@mapbit.com
    Jan 11, 2013
    8
    The problem is back
    Still getting ACK is not received from sip message and outbound calls droping from Aastra 6730i desktop phone.
    This is frustrating any other good suggestions ?
  11. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Have you run a firewall check on your 3CX system, it seems like a network (NAT) issue.
    For remote extension site, it could be also a firewall / NAT issue. Can you check normal operation with other phone or 3CX softphone.
    Regards
  12. pbueno@mapbit.com
    Jan 11, 2013
    8
    Firewall check on 3CXphone systems returns all ports as successfull. 3CXPhone softphone on remote Windows PC works perfect. Aastra 6730i on the same remote lan as the windows pc works fine for inbound calls but drops all outbound calls after 30 seconds with
  13. complex1
    Jan 25, 2010
    829
    50
    Don't you have by chance another IP-phone, not a softphone, to test the remote connection?
  14. pbueno@mapbit.com
    Jan 11, 2013
    8
    We only have Aastra 6730i Phones. This is becoming a real problem.
