Ack not received call terminated 3CX8/9/SP1/SP2
Discussion in '3CX Phone System - General' started by bmcosier, Sep 4, 2010.
  1. bmcosier
    Sep 4, 2010
    On one of my VoIP providers, all inbound calls are terminated by 3CX after 30 seconds. This never happens when using a Lynksys box direct with the provider, it only occurs on 3CX.
    The 3CX log shows:
    Ack not received
    Call terminated.
    Wireshark is showing that 3CX is initiating the termination - all BYE requests come only from 3CX.
    This is only happening on 1 of 3 inbound lines, and occurs regardless of the extension which answers. Outbound calls are fine.
    It happened to me with 3CX version 8 (intermittantly), v9, SP1 and SP2. I am currently running 3CX Phone System v9.0.13545.594 SP.2 and it is faulting every time I test.
    I've searched the forums and the net, it seems it is or was a known bug that may have a patch. Can anyone help me?
    Thanks,
    Ben Cosier
  2. emitosi
    Mar 25, 2009
    Hi, I have the same problem, version 9.12967. If I connect to sip provider without 3CX everything is right.
