Acrobits Softphone on iphone
Discussion in '3CX Phone System - General' started by mhnichols, Apr 28, 2010.
  1. mhnichols
    May 22, 2009
    11
    I am using Acrobits softphone on the iphone, to connect to 3cx, but am using the pptp VPN functionaility on the iphone to open up a tunnel to keep the call secure rather than opening up our 3cx server to the outside world.
    all works fine and the call is great, but i seem only able to use the ulaw codec.
    I have the g729 codec on acrobits, but if I set this to be the only codec to be used I seem unable to make a call.
    It looks like i may be missing something on the server to allow g729 to be used, but i am using a 24 license version with 12 g729 channels?
    Any ideas on how to get the g729 channels to work?
    Mark
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    I will try and test this for you never did give it a shot in VPN mode. Will get back to you on this one.
  3. Alexsch
    Mar 16, 2010
    Hi there ,
    The application Acrobits Softphone on iphone does not exist on the Greek appstore, does anyone know where can i get it or if there is a similar app to make iphone work on 3cx? i try the app name Adorephone with success when i call other extensions but with no luck when i have an incoming call (no Voice at all).
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Well im not too sure what is available on the greek appstore. But all I can suggest is too look closely at the reviews and download accordingly. Sorry I can help you more, maybe other people have some kind of workaround to installing software that is not available in your country.
