Solved Activate Call Waiting
Discussion in '3CX Phone System - General' started by Moawia Noor, Jul 17, 2017.
  1. Moawia Noor
    Mar 12, 2017
    24
    Hi , we are using V14 , I can activate call waiting for one extension by enabling the busy status .
    Is there a better way for achieving this for all the extensions at once .
    Regards,
    Mo.
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @Moawia Noor,
    You can select multiple extensions by holding the Ctrl key on your keyboard, and click on the extensions you wish and click on "Edit".
    Moawia Noor likes this.
  3. Moawia Noor
    Mar 12, 2017
    24
    That was easy , thank you very much , appreciate your response .
  4. Panayiotis_3CX
    Apr 26, 2017
    165
    7
