activate/deactivate the voicemail manually
Discussion in 'Ideas' started by Harrouchy, Dec 29, 2017.
activate/deactivate the voicemail manually 5 5 1votes
5/5, 1 vote
  1. Harrouchy
    Dec 29, 2017
    It will be interesting to have an option for the user to activate/deactivate the voicemail manually from the phone set (in this case Snom D710)?
    Kind regards,
