Activating Mailbox and Dial Rules
Discussion in '3CX Phone System - General' started by suppenhuhn, Sep 15, 2008.
  1. suppenhuhn
    Sep 15, 2008
    is it possible to activate/deactivate the Mailbox and the different dial rules using a certain telephone code, e.g. if I dial 5001 on the phone, my answering machine is turned on, with 5002 its turned of. The same regarding the dial rules... Or is it possible to do this with the mail key from e.g. a Grandstream GXP 2000 phone?
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    This is not possible to achieve.
    However please do forward this as a feature requests on the feature request forums.
    regards
  3. suppenhuhn
    Sep 15, 2008
    Thanks for your responses.
    But how do you activate/ deactivate the mailbox then? Only using the webinterface?
  4. Nebula
    Nebula New Member
    Apr 6, 2008
    116
    Do you mean activate/deactivate as an administrator or a user?
    As administrator it is under Extensions/Manage/Ext no/Voice Mail Configuration.
    As a user: http://<phone-system>:5481/myphone/
    Specify your extension number and PIN and click ‘Login’
    However the user portal option is only available on commercial editions.
    Hope this helps
