Active calls with codec info
Discussion in '3CX Phone System - General' started by gse, Mar 20, 2014.
  1. gse
    gse
    Mar 19, 2014
    I'm looking for a way to get a list of all active calls, and have the ability to drill down on them.
    In extensions status, I can see the status of each extension, but I'd also like to be able to see all active calls and find out, for example, what codecs are being used, IP addresses of endpoints, etc.
    Is this possible?
    10,872
    304
    The 3CX Server Log, in Verbatim mode (check box at the top), should give you all of that information, but only as a snapshot of what has happened.
