Activity Log changes
Discussion in 'Ideas' started by craigreilly, Feb 17, 2017.
Activity Log changes 4.8 5 6votes
4.8/5, 6 votes
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    304
    1) If not using STUN - then system should not report this erroneous bit of information:
    02/17/2017 9:51:27 AM - STUN servers list is empty, no STUN discovery is possible
    02/17/2017 9:51:27 AM - STUN discovery of public IP is disabled
    2) If there are no active calls, you do not have to tell me such every 30 seconds. Maybe an option to enable/disable.
    02/17/2017 9:51:24 AM - Currently active calls [none]
    3) The SEARCH functionality is not helpful. I need to scroll to bottom and load more records over and over again and then do a SEARCH. If I SEARCH for something - it should look thru all of the currently available ACTIVITY LOG and bring up the results. If this is not possible, perhaps an EXPORT to CSV button on this page?
  2. marcusjclifford
    Apr 17, 2012
    25
    Just found this thread via searching.
    I agree on all the above points, in addition the Low / Medium / Verbose log settings are too generic, and either show far too much or far too little logging.
  3. MARLEY JAFFE
    Oct 20, 2018
    22
    I'm amazed that there is no Export option on the Activity log... Seems like easy functionality for them to implement.
