Activity Log Logging Level
Discussion in '3CX Phone System - General' started by ntnetzeband, Oct 25, 2017.
  1. ntnetzeband
    Jul 30, 2016
    65
    5
    How much does changing the activity log logging level to verbose actually affect CPU usage? Enough to the point where it could cause poor audio quality on phone calls.
    We are troubleshooting issues a lot with 3CX so we need to keep the logging level at verbose it seems like all the time. If we switch back and forth between low and verbose, do we need to do any service restarts or it kicks in automatically.
    We are using V15.5 for our firmware.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,341
    535
    Hello @ntnetzeband
    That depends on how busy the system is, number of calls, how many extensions there are etc and how good the machine is and the speed of the hard drive. It is not only cpu usage that is affected but the hard drive and memory as well especially if recordings are enabled also. Generally we do not recommend leaving Verbose logging on but if your machine is capable then its your decision.
  3. ntnetzeband
    Jul 30, 2016
    65
    5
    If we change back and forth between verbose and low logging level, do any services have to be restarted?
  4. YiannisH_3CX
    May 10, 2016
    7,341
    535
    For the changes to be fully applied you need to restart services.
