Activity Log not working correctly
Discussion in '3CX Phone System - General' started by TSlocum, Jul 25, 2016.
  1. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    The search in the activity log isn't working. When I search for a number that I know is in the logs, nothing comes up.
    Also, when I click "Show more" at the bottom, it just adds newer logs to the bottom, instead of going back in time in the logs.
    For example,
    12:04:56
    12:04:55
    12:04:54
    Click show more
    12:05:12
    12:05:11
    12:05:10
    Currently the activity log is completely useless.
  2. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    Has anyone at 3CX been able to look at this? It's still not working in 15 SP1.
  3. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    @TSlocum, yes we indeed see the problem and we will tackle it with a fix in the next the update. Also we are planning to optimize Active Calls and provide a refresh button.
    I suggest for now to search via call or more over use Bin Log Viewer for the time being.
    Thanks again for reporting.
