Adapter for FAX machine
Discussion in '3CX Phone System - General' started by Flash99, Nov 8, 2017.
  1. Flash99
    Aug 3, 2017
    98
    8
    We need to connect a few FAX machines to 3CX
    I know its not the best idea and it may not work all the time, but still we need to connect
    What adapter would you suggest to use ?
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,251
    203
  3. Flash99
    Aug 3, 2017
    98
    8
    Any chance for something a bit more widely available ?
    I can live with manual configuration
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    Please try SPA3102 (EOL), now a unsupported device, but long time ago it was a supported by 3CX or try the Grandstream HT-503 running on firmware 1.0.14.100 (NOT the latest one)
  5. Flash99
    Aug 3, 2017
    98
    8
    Thanks I already tried Grandstream on latest firmware and it wasn't so good.
    Will see if I can find SPA3102
  6. complex1
    Jan 25, 2010
    814
    49
    Please do NOT use the latest firmware. It sucks. Use firmware 1.0.14.1 or 1.0.14.100
  7. Flash99
    Aug 3, 2017
    98
    8
    I was hopping to find some device that will work normally without "special needs" like old firmware
    But I will try to downgrade to 1.0.14.1 or 1.0.14.100 and check how it works
  8. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    Grandstream HT-701 or 801, Cisco SPA112 or 122
  9. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,423
    187
    Hi Flash 99,
    The Patton Smartnode FXS 411X range are in my view the best devices to use with 3CX that support FAX. They are auto-configurable from the management console and very solid: https://www.3cx.com/voip-gateways/patton-smartnode-sn4112-fxs/
    I would add however that FAX for hosted systems is not currently supported for SBC and STUN (although I have heard some word that this will change shortly) VPN is OK though.
    Is this FAX requirement crucial to the customers business ? although an FXS device is a good option they could always move across to an online FAX service (if not required for legal reasons for example).
  10. Flash99
    Aug 3, 2017
    98
    8
    Unfortunately FAX is crucial
    Its going to be on the LAN with 3CX so at least this is not a problem
    Patton is also not so widely available
  11. sip.bg
    Nov 7, 2016
    704
    220
    AudioCodes Mediant MP112 for best results.
    VoIP provider must support T.38
