Add 3rd Caller
Discussion in 'Windows' started by DungaBee, Nov 18, 2010.
  1. DungaBee
    May 28, 2010
    Hi all.
    I am using the 3CX Softphone to connect to our existing hosted VoIP provider. Is there a way to add another caller to a call when you are on a call with someone else already? I had previously been using a Polycom desk phone and I would simply place one call on hold, call another person and then link them together.
    Is that possible with the Softphone?
    Thanks!
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Hi, I don't believe this feature is available via the 3CX Softphone, I know Xlite supports this feature.
