Add a text note (on sip trunk, extension, IVR, Queue, etc)
Discussion in 'Ideas' started by AlexanderHanna, Nov 2, 2015.
  1. AlexanderHanna
    AlexanderHanna New Member
    Oct 2, 2015
    100
    12
    Extension Note Field
    It would be great to have a field that one can make notes on each extension. This field can easily be added under the "Other" tab. This will be helpful in allowing one to make important notes about how an extension is setup and the reason it is setup this way.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    Re: Extension Note Field
    Perhaps extend this to Queues, Ring Groups, DID's, etc.
  3. Lawrenceb
    Nov 11, 2015
    6
    Description field for inbound rules
    When the number of inbound DDI numbers that you are managing gets around about 100 it would be useful to be able to assign free-text descriptions to them so that administrators can give DDIs labels to make it clear what they are used for - i.e. easily be able to distinguish DDIs which are currently free and not assigned to a user/queue
  4. telin
    Jul 28, 2015
    54
    6
    I just figured that sometimes it is difficult to keep track of different changes you make on the system.
    Especially, when there is a lot of extensions/rules/ring groups and other things set up.
    I am thinking if simple text field "Note" could be added to some of the selections.
    There is huge potential use of this feature for an administrator or a tech, especially, when a huge team manages the server.
    HTML type editing, maybe?
    I believe that these fields would largely benefit from this:
    Extensions
    Group of extensions
    Sip trunks
    Port
    Inbound/Outbound rules
    IVRs
    Ring Groups
    Call Queues
    Bridges
  5. PaulD
    Jul 4, 2010
    90
    11
    Agree. Will 'upvote' but see this thread too .....
    http://www.3cx.com/forums/notes-section-43719.html
  6. telin
    Jul 28, 2015
    54
    6
    Oh...
    Upvoted this one as well.
    Let's see, if any of them get approved.
    Cannot find a way to delete the thread.
  7. PaulD
    Jul 4, 2010
    90
    11
    Re: Description field for inbound rules
    Yep, I support this, we have 800 DIDs ...... in fact it would be useful to have this on all entities - extensions, ring groups, queues. Trivial programming cost and server load but would add huge flexibility for large users, especially if is was multi-line. There are other threads on this subject but not much enthusiasm I fear ......
    Upvoting ....
