add a way to delete old greetings
Discussion in 'Ideas' started by Miriam, Aug 31, 2017.
add a way to delete old greetings 5 5 9votes
5/5, 9 votes
  1. Miriam
    Aug 31, 2017
    At the moment there is no way to delete old greetings that I've recorded in voicemail. I'd like that. Thanks!
    datamerge likes this.
  2. dab
    dab
    Nov 1, 2009
    67
    Also for holiday or other greetings.
    giwm likes this.
  3. Sue B
    Wednesday
    I agree, I cannot believe this is not possible!
  4. Bruno PELZER - CELEM
    Dec 11, 2017
    28
    If your 3CX is linux based, you can delete wav files with WinSCP or in SSH... Files are located here :
    /var/lib/3cxpbx/Instance1/Data/Ivr/Data
  5. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    You can do the same in Windows - AS AN ADMIN. It would be nice if end user could delete - from webclient say - so they don't use it by accident. They can instead delete it.
  6. ConnectworksNL
    Mar 2, 2017
    56
    15
    And also for Hosted 3CX phone systems, there you cant delete the items, so should be a delete button
