Add account Manually - Android
Discussion in 'Android' started by sanketgroup, May 29, 2017.
  1. sanketgroup
    Jun 28, 2012
    97
    Hello
    How can I add account manually in Android?
    Previous version had this option.
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    258
    13
    This option does not exist anymore
    Thank you
  3. sanketgroup
    Jun 28, 2012
    97
    really?
    we will have bigger problem. Why removed?
    Also, when account is added automatically, and if we make any changes in profile within App, it get lost on re-login to App
  4. Marios Neophytou
    Mar 1, 2016
    258
    13
    This has been removed a long time ago. What options are you changing and you cannot re-login? Can you be more specific so I can find a solution of your problem
    Thank You
  5. sanketgroup
    Jun 28, 2012
    97
    If android client change Display Name, it gets changed back to original on re-login
  6. Marios Neophytou
    Mar 1, 2016
    258
    13
    You have to disable re-provision on startup from Management Console and then change the name. Click on the extension > Phone Provisioning > Disable Re-Provision on startup.
    Thank You
