add callednum to 3cxphone parameters
Discussion in 'CRM / Helpdesk / App Integration' started by eran322, Jun 17, 2017.
  1. eran322
    Feb 9, 2013
    8
    hello.
    i using the 3cxphone for 12.
    when call incoming its opening some little program that i did and send this parameters to it:
    %CallerNumber%:%CallerDisplayName%
    its work very good.
    but i very want to add the callednum to send parameters like caller number, is this possible in 3cx phone?
    if not, does i can replace the callsernumber and add to it the called num?
    thanks alot
    eran.
