Add %%CALLER_RESOLVED NAME%% to Template Parameters
Discussion in 'Ideas' started by Lev, Oct 22, 2015.
  1. Lev
    Lev New Member
    Sep 19, 2015
    119
    17
    We receive Fax via Email. To have a better searching experience in Outlook (or whatever you use), it would be handy, if 3cx would check the companies address book for the callers id, resolve the callers name and add it as a new parameter (%%CALLER_RESOLVEDNAME%%).
    This could then be used in the "from-field" for example.
    Additional there could be a even new variable %%CALLER_RESOLVEDEMAIL%%.
    This could maybe be used to enable direct email-replies for inbound faxes.
  2. ip19
    Feb 7, 2011
    15
    It should be present in ALL templates
