Add DSS-Key type "Custom Key" for Yealink-Phones
Discussion in 'Ideas' started by decalabs, Dec 13, 2017.
Add DSS-Key type "Custom Key" for Yealink-Phones 5 5 8votes
5/5, 8 votes
  1. decalabs
    Sep 21, 2016
    15
    we have some customers which are using Yealink T46S phones and they need a BLF-Key to dial a number when pressed, then waits 2 seconds and then sends a PIN as DTMF. With Snom-Phones this can be set as a normal Custom-Speed-Dial-Key fast and easy.
    On Yealink-Phones this has to be a BLF-Key with the type "Custom-Key" and you have to enable a custom parameter in the provisioning template, as described in this document:
    http://support.yealink.com/faq/faqInfo?id=539
    When I set everthing manually it works perfectly. But I cannot set this through 3CX, because I don't have "Custom Key" in the BLF-type-dropdown. Only Blank,Line Key, BLF, Speed Dial, Custom Speed Dial, Shared Parking, Agent Login/Logout and Shared Status.
    So my request is to please add the "Custom Key" option to the BLF Key settings.
    Best regards,
    Dino
    extremit likes this.
  2. JakeC
    Jun 11, 2018
    21
    Is there a solution for this yet? Would be great and very much appreciated!
