Add external sip account
Discussion in 'Android' started by David Sokolic, Feb 4, 2017.
  1. David Sokolic
    Dec 28, 2016
    9
    Is there a way to add an external SIP account to the Android client? I don't see any option to add one. I would like to be able to use the 3cx PBX as well as a personal SIP account to make personal calls from the same client.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,545
    298
    If I recall, 3cx client only works with 3cx now.
  3. leejor
    11,079
    324
    You'd have to go back to one of the older versions that wasn't tied to a particular PBX release.
