Add line keys to the Fanvil X4 phone template
Discussion in 'Ideas' started by Phone systems NZ, Mar 8, 2017.
  1. Phone systems NZ
    Feb 15, 2017
    53
    16
    I would like some line keys added to the BLF key template for the Fanvil X4 phone. there is currently none so you cant handle multiple calls on this phone. all the ways to add the keys are not supported by 3CX so please vote for this so they will update there template.
    Thank you.
