Solved Add multiple inbound route by bulk or copy
Discussion in '3CX Phone System - General' started by ahmedsza, Feb 19, 2017.
  1. ahmedsza
    Jan 4, 2015
    17
    Dears
    I have 2 sip trunks and every trunk has 10 lines and need to add inbound route for every number
    is there any way to add one and just copy the configuration with ability to change, for change the
    did number ?!
    Its to hard and pain adding one by one.
    Thnks
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Not sure what you mean by having 2 trunks of 10 lines each, but you can create one DDI rule, export it to .CSV file, open it in Excel, do whatever you like to copy and edit the records and import the edted file back to PBX. See: https://www.3cx.com/blog/docs/importing-dids/
  3. GiannosC_3CX
    GiannosC_3CX Guest
  4. ahmedsza
    Jan 4, 2015
    17
