add phone with customized provisioning template @ phone tab
Discussion in 'Ideas' started by BayMitch, Mar 27, 2017.
add phone with customized provisioning template @ phone tab 4.7 5 3votes
4.7/5, 3 votes
  1. BayMitch
    Sep 3, 2013
    13
    5
    Hi all,
    in foreign versions of 3CX it you were be able to add a phone with a customized provisioning template.
    I know...... customizing a a provisioning template is not supported......... :(
    But this will not hold 3CX to make it possible to add a phone in the phone tab to an extension with a customized template.
    So make it possible to add a phone with a customized template.
    greetz Remko
    Jeremy Mulder and Twan Hermans like this.
