Add Possibility to activate separate speaker in Windows Client for PC
Discussion in 'Ideas' started by coorga, Jun 15, 2017.
  1. coorga
    Feb 17, 2016
    As it is possible an almost any phone, we would like to have the possibilty to activate an additinal speaker in the Windows Client for PC in order to let other people in the room listen to what the other party says.
