Add Prefix to Call
Discussion in 'Call Flow Designer' started by ntnetzeband, Oct 20, 2017.
  1. ntnetzeband
    Jul 30, 2016
    65
    5
    We have bridges between offices but employees frequently forget or won't dial the prefix to route across the bridge to the correct office.
    Is there any way to use CFD to do this where if they don't dial an extension in their office then it will prepend the appropriate number so it gets routed across the bridge.
    Please note that each 3CX Server has all the exact same extensions due to different failovers we have set up so an outbound rule does not work properly.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,080
    77
    Hi @ntnetzeband,
    Unfortunately the CFD will not help you with this. A CFD callflow will only process calls to the queue where it is deployed. It can't handle any call in the system. Also, there is no way to change the dialed number, not even using the Call Control API...
    Kind regards.
