Add voip line problems
Discussion in '3CX Phone System - General' started by caojun76, Jan 15, 2008.
  1. caojun76
    Jan 14, 2008
    6
    If there is anybody here meet with the same problem with me, I am using the same Authentication ID for my different voip provider such as voipstunt, inphonex and local provider, but when I am adding for VOIP lines, I can only add one of them, when I am adding the second one, the system remind me that the Authentication ID should be unique, but since I am using the different provider, why it should be unique?
    I think there must be some problem with this, anybody here can help me to solve this problem.
  2. caojun76
    Jan 14, 2008
    6
    Any person here can give me some instruction to solve this problems? :(
  3. silentfun
    silentfun Member
    Dec 11, 2006
    364
    perhaps the databasefield is set to unique
    to get the right info you have to cantact one of the officials in this forum.
    best u give a PM to Costas3CX or kevin
    Andy
  4. caojun76
    Jan 14, 2008
    6
    Thanks Andy!
    I have already send P.M. to them.
  5. caojun76
    Jan 14, 2008
    6
    Why it seems there is nobody answering for my questions?
  6. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Probably because no one is having that issue?
    All my lines are either DID's coming from the same provider with the same unlimited channel or they have seperate IDs.
  7. Andy Schmidt
    Andy Schmidt New Member
    Apr 3, 2008
    118
    The problem is that they created an index "externalline_authid_key" over the authid column in the externalline table - but they made it a "unique" key, rather than allowing duplicates.
    I'm not clear what functional reason would have 3CX require that VARIOUS providers can NOT use the SAME authid?
    If my company is "H&M SYSTEMS", then it's not at all farfetched, that DIFFERENT providers would (and indeed have!) used the "logical" user name of "hmsystems".
    I think this may be a bug in the database schema? Some programmer wanted to have an index for faster lookup (good), but made it "unique" (which is the problem).
