Add VoIP Line
Discussion in '3CX Phone System - General' started by sonlm, Oct 12, 2007.
  1. sonlm
    Mar 28, 2007
    13
    I have problem with 3CX when adding VoIP line :)
    I have a free account from VoIPTalk (VoIPTalk.Org)
    External Number: 88484787
    Authentication ID: 88484787
    Authentication Password: ******
    Registrar/Proxy Hostname or IP: voiptalk.org
    Outbound Proxy Hostname or IP: nat.voiptalk.org:5065
    Registrar/Proxy Port: 5065
    Outbound Proxy Port: 5065
    STUN server Port: 3478
    STUN server Hostname or IP: I left it blank
    Outbount rule is 8
    The VoIP Line status is still "Not Registered" (in red)
    When I make call out via VoIP line (with prefix 8) to another VoIPTalk acc - on an IPPhone - it's OK (phone was ringed).
    But from this IPPhone call into the PBX (call 88484787) is not possible (receive disconnect signal).
    During calls, the VoIP line status is "Not Registered"
    VoIPTalk Accs are OK (tested with 2 IpPhone)
    Is there something wrong?
    Best regards,
    Sonlm
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Can you provide us some logs?
    Cheers
  3. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    3CX uses port 5060 by default. Your settings you said were to 5065. Did you change the 5060 to 5065 in 3CX?
  4. ihasham
    Dec 4, 2007
    Port numbers
    The port for VOIP talk is as follows:
    Registrar/Proxy Hostname or IP voiptalk.org 5060
    Outbound Proxy Hostname or IP nat.voiptalk.org 5065
    Kind regards,
  5. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    This Voip provider works out of the box with 3cx. Given the settings are correct it registers immediately and I was able to make outgoing and receive incoming calls.
    Do not use the Outbound proxy setting and use the Generic Voip Provider. Do not use the Sip Trunk.
    Dtmf works and even transfers.
    Regards
