Adding a 2nd phone number
Discussion in '3CX Phone System - General' started by petewatterschats, Mar 24, 2016.
  1. petewatterschats
    petewatterschats New Member
    Jan 19, 2016
    151
    I selected FlowRoute as my trunk provider and just bought a number so I cold learn the 3CX system and gain some experience.
    Now I am porting one of my live numbers to FlowRote and could use some advise as to how I should set it up.
    Do I create a new SIP Trunk and use the same Port Details except for the new number
    Or should I just add a DID to the existing Port
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    385
    52
    If you are porting it to the same flowroute account, add it as a DID. If you added it to a separate new flowroute account then setup the new trunk.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,968
    180
    I do not know if the Flowroute template has been updated... but take note:
    The Source ID page needs to show
    "Sip Field containing DID Numbers: Request Line URI: User Part"
    This was not the setting when I selected Flowroute - but perhaps the template has been updated. With the original setting, some calls that had Diversion information were not getting thru.
