Adding a line to the conference.
Discussion in '3CX Phone System - General' started by radix, Feb 23, 2009.
  1. radix
    Feb 5, 2008
    23
    How it is possible to add a call from a line to a conference?
    Example:
    I'm creating a conference room on Line 1 then I select Line 2 where I dial a number and then I want to add this Line to the conference room without that I'm being disconnected (by using transfer)
    How Is this possible with 3cx client?
