Adding a SIP trunk
Discussion in '3CX Phone System - General' started by UDAY, Oct 2, 2009.
  1. UDAY
    Oct 2, 2009
    Hi I am new to3CX and wanted to connect to a AASTRA MXone using SIP trunk. Can you advice me on how to add this??
    regards
    Uday
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    I havent used the MXone but if it can connect to a SIP trunk then its not that hard, you just create a trunk on the MXone that points to 3CX and vice versa.
