Adding date to the server Log
Discussion in '3CX Phone System - General' started by q, Jul 17, 2007.
  1. q
    q
    Jul 17, 2007
    Is there a configuration switch to add the date to the time field on the server log page?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    You can found the logs files at (by default)
    Current day
    C:\Program Files\3CX PhoneSystem\Data\Logs\
    Logs backup path (Should be keep 7 days)
    C:\Program Files\3CX PhoneSystem\Data\Logs\Backup
  3. q
    q
    Jul 17, 2007
    Thanks for the reply.
    The log only contains the tme in the first field, is there a way to also include the data (date & time) in the first field.
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    The current version 3CX Phone System v3.0.2328.0 no option for keep 7 days full log.
    Please create a batch file as below and daily run by scheduler. During restart the services all the calls will be drop without warming.
    net stop "3CX PhoneSystem"
    net stop "3CXPhoneSystemWebServer"
    net stop 3cxivr
    net stop "3CX PhoneSystem Media Server"
    net stop 3cxvboxmgr
    net stop "3CX PhoneSystem Database Server"
    del /q /f "C:\Program Files\3CX PhoneSystem\Data\Logs\*.7"
    ren "C:\Program Files\3CX PhoneSystem\Data\Logs\*.6" *.7
    ren "C:\Program Files\3CX PhoneSystem\Data\Logs\*.5" *.6
    ren "C:\Program Files\3CX PhoneSystem\Data\Logs\*.4" *.5
    ren "C:\Program Files\3CX PhoneSystem\Data\Logs\*.3" *.4
    ren "C:\Program Files\3CX PhoneSystem\Data\Logs\*.2" *.3
    ren "C:\Program Files\3CX PhoneSystem\Data\Logs\*.1" *.2
    ren "C:\Program Files\3CX PhoneSystem\Data\Logs\*.log" *.1
    net start "3CX PhoneSystem Database Server"
    net start 3cxvboxmgr
    net start "3CX PhoneSystem Media Server"
    net start 3cxivr
    net start "3CXPhoneSystemWebServer"
    net start "3CX PhoneSystem"
  5. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    If you open 3CXPhoneSystem.ini file and change $ShortDT to $FullDT for the format settings of 3CXPhoneSystem.log file - you will get it. But I doubt it will fit current column size in server status page. And I doubt you can change that size. Anyway - you may try it and decide if it is better or not :)
  6. q
    q
    Jul 17, 2007
    Thanks Archie...it worked great after I made one change to svr_status.php
    preg_match_all('/^\d\d:\d\d:\d\d[.]\d\d\d.+$/m', $log_data, $out);
    To:
    preg_match_all('/^\d\d\d\d[\/]\d\d[\/]\d\d[-]\d\d:\d\d:\d\d[.]\d\d\d.+$/m', $log_data, $out);
    I will work allowing it to handle either $ShortDT or $FullDT later and to remove the "-" from the date/time display.
    Have a great day!
