Solved Adding DDI's to Beronet Gateway one at a time
Discussion in '3CX Phone System - General' started by GBC_James, Oct 3, 2017.
  1. GBC_James
    Feb 3, 2017
    50
    6
    Hi All
    We have a Beronet gateway which is connecting our isdn lines on to 3CX (once working we intend to ditch the isdn's and port all our ddi's to our new sip provider)
    Having successfully set up the gateway in 3CX, my question is, do I really have to add 600 DDI's one at a time?
    Each time I add one, I have to scroll up to the top and click add again. It is tedious and my co-workers say I'm grouchy.
    Tell me this isn't really so.
    James
  2. Rory
    Dec 9, 2016
    17
    Can you not export your current Outbound Rules to CSV and change the Ports field to match your SIP trunk and then reimport?
  3. Rory
    Dec 9, 2016
    17
    Sorry Inbound Rules
  4. GBC_James
    Feb 3, 2017
    50
    6
    there is no import feature.
    Sip Trunks - Beronet bero*fix Pr i- DID's
    There is only the +Add DID button
  5. Rory
    Dec 9, 2016
    17
    Hi James, So you have added all your DID's to your SIP trunk and created Inbound rules for all of them?
    Then under Inbound rules, you should be able to export your Inbound rules to CSV
  6. GBC_James
    Feb 3, 2017
    50
    6
    Hi Rory
    No. We have no DID's in our sip trunk yet.
    Our current Mitel phone system has 2 IDSN lines. As we move over to 3CX we are first using a Beronet gateway to connect our existing 2 isdn lines to our 3CX.
    This we have done successfully. However, in the gateway settings (same place as sip trunk settings in 3cx) there are no DID's showing under the DID tab.
    So we are having to add them manually.
    Eventually, once we have successfully replaced all our users phones and have been using 3cx error free for a month our so, we will THEN transfer all our DID's off the isdn lines and over to our Sip provider.
    So at this point, in 3CX, under Sip Trunks we have our sip trunk listed AND a baronet gateway.
  7. GBC_James
    Feb 3, 2017
    50
    6
    So just the add DID button, no import :(
  8. neville
    neville New Member
    Apr 23, 2012
    201
    33
    Manually enter a couple of the DID's and set the inbound rules.
    Export two or more of the inbound rules that is set the way you want it so you can get the correct settings.
    Enter the DID's and correct settings into the excel document.
    Import into Inbound rules and the DID's will be added to the trunk.
    This is how we do it.
    Message me if you have issues.
    YiannisH_3CX likes this.
  9. GBC_James
    Feb 3, 2017
    50
    6
    Thank You very much @neville You are a genius and we shall be raising a glass to you tonight.
    Using your method we have finished our DID import in record time
    you are awesome :)
